@n Drive for Front Loader Hydraulic Pump
Bill
03-04-2001 16:24:30
I have a front loader on my 2N. The pump for the hydraulics mounts on the front loader and is driven by a shaft that fits into a splined pulley mounted to the crankshaft. It seems like every other year the splines on the shaft let go. Happened again today as I was moving some snow. Is there a better way to drive this pump, I'm getting tired of the splines tearing out and having to buy a new shaft at $40.00plus. Splined pulley isn't that cheap either. What about using a power steering pump to drive the front loader?
Fred OH
03-05-2001 12:16:19
 Re: @n Drive for Front Loader Hydraulic Pump in reply to Bill, 03-04-2001 16:24:30
Sometimes when the crankshaft pulley is removed with a puller, it gets sprung a little and it will wobble. Then the question is how do you get it straight again? I'd say that you would have to remove it and put it in a lathe in a 4 jaw chuck and get it running true with the crankshaft and then straighten with a soft hammer or wedges from behind being careful not to mar the seal surface or the pulley width. Reinstall on crank and put on female spline assy which should now run true and shouldn't wear out so soon. Makes you think about buying a new one, doesn't it? Kinda expensive though. L8R----Fred OH
Al English
03-05-2001 03:15:08
Hi Bill, Your power steering does not generate enough presure to replace your loader pump, and as Mike pointed out, the volume would also be very low...Al English
Mike OH
03-04-2001 18:02:43
Bill, I don't know how good a power steering pump would be to drive your loader; don't think you'd get enough gal / min out of it, but you shouldn't be tearing out the splines on the drive shaft. Sounds like an alignment problem to me, or shock loading, but don't see how shock loading would come into the picture. In order to have long spline life, both male and female splines need to be in good condition and they must be in good alignment. Your pulley doesn't have a lot of runout(wobble)in it does it? It would probably be a good idea to replace both shaft and pulley and make sure they are in alignment, both vertically and horizontally. You may have to reposition your pump or coupling to do so. Good luck! Mike
Jim WI
03-05-2001 10:52:08
 Re: Re: @n Drive for Front Loader Hydraulic Pump in reply to Mike OH, 03-04-2001 18:02:43
I second this.
If the shaft isn't exactly perpendicular to the drive plate, it will wear the splines very quickly. Had exactly this problem on my dad's tractor.
