Order Ford 8N Parts Online
8N oil pump
Terry
03-03-2001 13:38:06
I've got a 47 8N that keeps loosing oil pressure. I removed the pan today, and found a crack in the pick up tube to housing weld. I blew air through the tube, while holding my hand over the hole in the housing, and there's no air leaking at the weld. Can this ca use my pump from loosing prime. I don't understand how. I know I need to weld up the tube, but cant understand how this could cause it to loose prime. Also the oil pump plate has wear that I can feel. Should this be milled?
Nogrimace
03-04-2001 05:11:18
 Re: 8N oil pump in reply to Terry, 03-03-2001 13:38:06
Terry
I had a small crack in my pickup tube, I couldn't tell if it was a through crack or not(using shop air also) I welded it up and rebuilt the oil pump. The machine shop sized the bushing and checked for flatness. It works great now. It is a lot cheaper to rebuild the oil pump now that you have the pan off. I know when I bought mine 47 8N it had turned bearings caused by lack of oil pressure. Cost me a major overhaul. Good luck.
