Order Ford 8N Parts Online
8n hydraulics
Griff
08-31-2004 13:50:09
My 8n lift will not go up all the way. If I take the bracket off and pull the lever up way past where it is supposed to be it goes up just fine. Is there some kind of adjustment that I can make? I took the nut off of the lift handle but could not get the handle itself off. I also tried taking the four bolts out of the quadrant but I didn"t know what to do with it once I had them out.
Dave H (NY)
08-31-2004 15:36:43
 Re: 8n hydraulics in reply to Griff, 08-31-2004 13:50:09
Post a message her to Zane, he is a hydraulic genius and will get you fixed up.
CVRancher
08-31-2004 15:02:21
I had the same problem several weeks ago and recieved help right here on this board. I loosened the four bolts on the quartant and tapped that plate back about 3/16 " and the lift brought my back blade up about one foot higher. Hope this helps you out.
Goodluck,
Jim
