Order Ford 8N Parts Online
8N head gasket
Hawk (TN)
03-02-2001 05:08:28
I just installed a locally purchased overhaul kit. That is sleeves, pistons, bearings, valves,lifters - the whole works.Even a new distributer. Tractor started fine but slight ping. Pulled the head. Two pistons were slightly tapping the head. Went back to shop where I purchased the kit. The only suggestion they had was to put two head gaskets. I did not want to do this but did not see any other way. So I bought two head gaskets. When I got the new gaskets home I compared them to the one in the kit. The gaskets I bought not from the kit were .015 thicker than the one in the kit. Put on ONE head gasket and ping is gone.
Moral of the story - all head gaskets are not the same.
Hawk (East TN)
Al English
03-02-2001 08:48:41
 Re: 8N head gasket in reply to Hawk (TN), 03-02-2001 05:08:28
Hi Hawk, It sounds like things are missing each other by only a few thousand'ths. As carbon accumulates the knock may come back. If it does you'll have to do the water in the intake trick, or use a fuel addative to get rid of it. Good luck...Al English
