Bearing clearances
Dave Williams
03-01-2001 08:47:16
The manual I have does not list bearing clearances for my 8n .Need to know mains and rod specs. thanks for your help. Da
Ed Gooding (VA)
03-02-2001 00:49:53
 Re: Bearing clearances in reply to Dave Williams, 03-01-2001 08:47:16
Hi Dave: I hope the following spec info will be useful to you in your rebuild:
Engine Clearances and Dimensions
third party image
Capacities, Torque Values, Bearing Preload, Misc. Specs
third party image
Regards..... ..... Ed
'52 8N475798
Al English
03-01-2001 11:28:19
Hi Dave, .0015" to .002" is ideal. I wouldn't go any tighter than .001" clearance unless you have spent a lot of money insuring EVERYTHING in the engine is perfectly round, straight, aligned, etc.(some of the new stuff has only .0005"!) I don't like to see more than about .003" clearance on a fresh engine. Along with this, verify(measure) that the bores in the block and rods are not worn or stretched oversize, as this can cause numerous problems. Good luck...Al English
TimK
03-01-2001 11:53:17
 Re: Re: Bearing clearances in reply to Al English, 03-01-2001 11:28:19
Suggest you check/renew rod bushings also.
