Alternator light
Mike
02-27-2001 17:45:24
What kind of light do I need to buy to excite my alternator? Also what size resistor do I need to get for the wire going to the coil? any imput will be greatly appreciated.
Claus
02-28-2001 08:11:24
 Re: alternator light in reply to Mike, 02-27-2001 17:45:24
AC Delco Recommends a 10 ohm 7 watt resistor for the exciting the Alternator. Radio Shack has a 10 ohm 10 watt wirewound resistor that will work satisfactory. Others prefer use of a "Side Marker Lamp". As far as the resistance you need for the coil, it depends a lot of the type of coil you have. Basically if you want to drop 12 volts to 6 volts, with a coil current of 3 amperes, you would need a 2 ohm resistor. R=E/I (2=6/3) 18 Watts min.
Happy Motoring
Claus
