Hyd Piston Removal
Craig
07-18-2004 06:50:46
Hi all,another question.
On a NAA when you have the Hyd. cover off.
How do you get the piston out?? I really do
not want to disassemble any of the valves.
The book says use air pressure, but there
must be check valves in there.What did I overlook? Thanks for any ideas..Craig.
denton
07-19-2004 07:16:12
 Re: Hyd Piston Removal in reply to Craig, 07-18-2004 06:50:46
Don't point that piston anywhere near your torso when you apply the air pressure. The piston comes out like a cannon ball and will make a dent wherever it hits.
Again, education hurts.
Ramon
07-18-2004 08:30:09
If you have the 'lid' off the center housing, remove the small plate on top that sits below the seat. I believe there will be 5 bolts holding it on. Then, there will be o-rings under that. Use the large port for the air. Watch the piston, for it will come out quickly and can damage fingers!
