Almost there, I hope.
Jeff Green
02-25-2001 09:24:31
I am getting near the end of a rebuild on my 8N407355. She was not running when I got her. The engine was rebuilt and today I started it for the first time. It ran a little. I checked the timing but it didn't seem very stable changing from 0� to 15� at near idle. Even at other throttle setting I could not get a steady timing reading. When rebuilding the engine, I didn't replace the distributor shaft or bushing but I did clean it up and check the cam weights. The shaft seems to have some free play. Could this be my problem?
Al English
02-25-2001 10:26:32
 Re: Almost there, I hope. in reply to Jeff Green, 02-25-2001 09:24:31
Hi Jeff, A loose distributor shaft will cause erratic timing. A good one should have almost no perceptible play. While you're at it check the advance mechanism for any obvious wear, sticking, damage, etc. One last thing, if the idle speed is too high the advance mechanism will come into play and advance the timing. Good luck...Al English
TimK
02-25-2001 18:47:47
 Re: Re: Almost there, I hope. in reply to Al English, 02-25-2001 10:26:32
I agree. A loose shaft will also wear out the rotor real quick.
