Order Ford 8N Parts Online
8n front mount distributor tune-up
Dan in Tennesse
02-20-2001 16:15:34
I need some help guys. I've pulled the front mounted distributor off my '48 Ford 8N. Cleaned it up, then installed new points and condensor. Now it's time to set the timing, but I'm a little confused on how to do this. I've read several methods on the correct way to do this, however they don't all agree. I'd like to get it right the first time, so any help (tricks, tips, etc) ya'll can give me is greatly appreciated.
James Lee (TN)
02-20-2001 17:43:59
 Re: 8n front mount distributor tune-up in reply to Dan in Tennessee, 02-20-2001 16:15:34
I time mine the static way using the manual. If you get it close it will start. I install the dist. but leave the timing screw snug, but not tight. After starting and engine warm up I time it while it is running, using a socket and extension. Move down until you here the engine start to load, then move up a bit until it unloads, then tighten the screw. Works real good for me.
Claus
02-20-2001 17:05:06
It would be easier to explain brain surgery than how to do the timing on the front mount. You have several options, A. set the timing in the middle and forgeddaboutit.. B. Get the It FO-4 Manual that has a good pictorial in it. C. Try Neils site, he also has a good pictorial.
Happy Motoring
Claus
LucVan
02-21-2001 07:30:47
 Re: Re: 8n front mount distributor tune-up in reply to Claus, 02-20-2001 17:05:06
I agree with Claus, The F04 manual is the way to go. Last summer I set the points in the field beside my house. Used the manual and went step by step and had no problems!
