Jubilee throttle friction disc
Dave Voegtlin
02-20-2001 12:09:42
I have a 1954 Jubilee and cannot get the throttle to hold which is particularly irritating when working the three point, and steering. I need a third arm/hand. It does not seem to matter how much I tighten the nut on the friction sandwich it will not stay. The surfaces are clean and dry and the disc that is sandwiched is probably original and is hard. The local Ford dealership cannot get a new one. Does anyone know what might be substituted for that disc?
Dave Voegtlin
02-21-2001 07:41:02
 Re: Jubilee throttle friction disc in reply to Dave Voegtlin, 02-20-2001 12:09:42
Thanks for the helpful suggestions. A steady throttle will be a wonderful experience!!
albe
02-21-2001 05:47:49
You might try to get the friction disk used for the lift quadrant. They appear to be about the same size. albe
Sam Mills
02-21-2001 04:18:10
Dave; The throttle friction disc is available at FNH. Part number NAA-99631A, about $8.00. The spring washer is P/N NAA-99778B, about $12.00.
walt
02-21-2001 09:02:28
 Re: Re: Jubilee throttle friction disc in reply to Sam Mills, 02-21-2001 04:18:10
Sam's right - I bought both last year from the Dealer
Tractor Rod
02-20-2001 15:24:21
Dave the disc for the three point lever is the same. If you can't find one let me know I have them in stock. Hope this helps Tractor Rod
John-COLO
02-20-2001 12:34:24
I once cut a piece of mule hide from an old hoseshoeing apron to replace this disc. It worked. John, tOTG
