OOps.. missed a couple questions. Yes.. the ballast resistor is the one mounted to the back of the dash. Virtually all the wiring on the tractor makes it by there.... easy to find if it is present.. While you can take an ohm reading on the primary and secondary of the coil.. most ohm meters aren't very accurate at a low scale.. least not the ones that you can find locally. The better way would be to hook up as usual.. and take voltage readings.. You want about 3 v on the top of the coil with the points closed.. and battery volts on the coil with points open. ( 2,5 to 3.5 is a fairly safe range.. much less will cause missing.. much more will overheat and degrade the coils insulation leading to premature failure. ) I notice you said you replaced the wires. Did you use solid copper wires.. or the modern carbon core anti-radiostatic wires? The antiradiostatic wires are resistor wires... you don't want them.. your front mount ignition coil is just barley adequate as it is, when running in great condition to get high voltage out to the plugs... there isn't much kv left over to 'give away' to losses int he system.. like dirty terminals.. fouled plugs.. and resistor wires. Also reccomend you use a champion h-12 plug or an al-437 plug.. or equivalents to those.. as they are a hotter range. Soundguy
