Order Ford 8N Parts Online
1952 8n repairs
Lyle Little
02-18-2001 11:29:00
I have a 1952 85 with a front loader/forklift. I was lifting 1500 lb bin off a flatdeck when the heavy load caused torque on the forks because thr load was a foot off centre. As a result the torque caused the oil pan and housing covering the front flywheel to split in half. the engine stoped right away with out any major damage I think. The question I have is what is my odds at success repair, or should I just sell for parts
joe webb
06-16-2001 12:48:10
 Re: 1952 8n repairs in reply to Lyle Little, 02-18-2001 11:29:00
need info on how to remove and over haul
hydraulic pump for 1952 8n ford tractor
LIFTING THAT MUCH W/8N
02-18-2001 15:07:25
IT SHOULD HAVE BROKE. GET A BIGGER TRACTOR FOR THAT KIND OF WORK.
bj/8N/mt
02-18-2001 13:10:57
guess these things aren't indestructible after all
with that much torque I would guess there is damage to the block too
if it were mine I would first see if it turns free with a wrench on the crank pulley nut then run a compression check and then plan my next move
almost anything can be repaired and if you were lucky you might be looking at only a used oil pan which you could get for less than a hundred from CT
good luck
