a back blade is a fine weapon for gravel driveways if you take the time to learn how it works. there is more art than science and the trick [if there is one] is how you set up any blade to grade the blade is adjustable in all three planes and if you set it up right it will do right think of the outside ends of the blade as "toe and heel". the center pivot of the blade gives you toe or lead and heel or follow [what would be the yaw axis on an aircraft]. set the toe a little ahead of the heel and figure the toe to dig and the heel to exhaust waste. normally you want to start with a little toe on the left looking forward. there is an adjustment on one of the three point lower arms that lets you set the blade off of horizontal [what would be an aircraft roll axis]. Start at level and figure how much lower you want the edge you want to dig [usually the toe] to get to the grade you want [level or otherwise]. you normally want it a little higher in the center [crown] so water drains and you normally want a curve to roll to the short radius of the curve [super] you can adjust the blade angle of attack [what would be an aircraft pitch axis] with the top link on the three point. start with the front/bottom edge leading a little but not much remember you have twenty five horsepower on a good day so figure it is going to take multiple passes and plan your pass and set the blade before you start then practice--a lot--by beer o'clock you will be giving lessons clear? worth two cents?
