O.T. Bandsawmill
fordsonfulk
04-13-2004 19:33:01
Just wanted to get some opinons on a bandsaw sawmill. I built one odds & ends & some new metal. It great for something that was homemade out of riding mower parts. I think i read on here a few yearsago that ( i think that Zane ) had built one cant remember.
Thanks for all response Fordsonfulk
ZANE
04-14-2004 05:31:08
 Re: O.T. Bandsawmill in reply to fordsonfulk, 04-13-2004 19:33:01
I would like to see what you built. I sold mine about six months ago for $700. Had more than that in it if you counted my labor but I never count that. It's cheap!
Mine worked pretty good but would only take a 16" log on the big end and that limited it sorta. Could make about a 12 board if you held your mouth just right.
Had trouble with early breaking of the blades. I think it was because of the diameter of the steel drive saw wheels and that it did not have any rubber like the Mizers have on the drive wheels. If I were to make another one I would use pulleys like the mizer so that it could use the rubber belt for the blade to run on. I think that is the secret to blade life. I might get to sharpen a blake one time before it broke. I really needed a blade welder or some way to put them back together. They always broke in the weld.
Send us some pictures/
Zane
fordsonfulk
04-14-2004 18:21:51
 Re: Re: O.T. Bandsawmill in reply to ZANE, 04-14-2004 05:31:08
I ordered plans off a guy on ebay used some of his ways and some of my parts like lawnmower wheels and tires axles 8hp kohler eng. pulley off cement mixer weights off a railroadcrossing signal 10ft self ends and a hole lot of mine work.
Thanks for the repy
I will try to put pictures on fordsonfulk,
MarkB 2N MS
04-14-2004 02:04:52
Never have built one, but helped feed and stack from a WoodMizer one day, and can vouch for the quality of their product.
Found the below thread on "Wood Web"
