Order Ford 9N Parts Online
9N brakes
Marty Nelson
03-21-2004 10:12:18
Does any one know how I remove the rear axles and brake drums?? Thanks Marty
Marty Nelson
03-21-2004 10:57:32
 Re: 9N brakes in reply to Marty Nelson, 03-21-2004 10:12:18
Is there anything in the rear end that will fall out or do i have to get the axel back in the exact spline that it came out of??
no . . . Dell (WA)
03-21-2004 11:09:10
 Re: Re: 9N brakes in reply to Marty Nelson, 03-21-2004 10:57:32
Marty..... ..while it ain't likely yer diffy axle socket is gonna move while ya gotts the axle out; it ain't likely yer 6-bolt axle hub is gonna move eather. But the answer to yer question is: NO, there is NO KEYWAY on the axle spline to match-up..... ....Dell
Bob
03-21-2004 10:16:27
You have to remove the nuts around the axle flange at the outer end of the "trumpet", and pull the axle and brake drum out as a unit.
