Order Ford 8N Parts Online
8N rear box/platform
Frank Jameson
02-11-2001 14:42:13
Would like to buy or make a platform or box to attach to the 3 point hitch of my 8N.Have seen these,but don't know where to find them. Any help much appreciated. Thanks
John Martinez
02-14-2001 19:38:25
 Re: 8N rear box/platform in reply to Frank Jameson, 02-11-2001 14:42:13
Frank, TSC has them for approx $70 or less. I have one which are made out of heavy angle iron,
holes drilled for attaching what ever type of box you desire. Also the pins for attaching to the3PT
I made my box out of 3/4 inch plywood, bolting the floor and the back. The sides and the back which are two doors are removable as they are attached on the sides with hinges at the top and bottom corners.
Steve Koch
02-13-2001 22:19:43
Another idea is to buy a simple fork lift attachment for your 3 pt hitch. I bought one, and plan to get a used large wooden fruit handling box (about 3ft sq and 3 ft high) from an apple orchard.
In the meantime, I have wooden pallets that I pick up with the fork lift for hauling things. Pallets also work great for getting your firewood. After you cut/split your wood, you can store it on the pallet to dry in a good spot, then drive it to your house to use, without restacking it.
Steve Koch
02-21-2001 12:56:10
 Re: Re: 8N rear box/platform in reply to Steve Koch, 02-13-2001 22:19:43
I think having a forklift attachment allows you to do so much more than just an implement that holds just a fixed box or platform.
My forklift is a Rankin, from Rankin Equipment Co of Yakima, Wa. Website:>Link
This last week I picked up a fruit box (per my prior post) and it is just perfect for hauling all sorts of things. I am thinking of hinging a door on one of the sides for easy access, instead of having to lean over to access small items that I may be hauling.
Steve (WA)
Bruce
02-11-2001 17:32:01
Frank, What you are after should be available at most farm stores. The Quality Farm & Country catalog list two, "3 Point Lift", for 49.99 & 129.99. Basically it is angel iron welded into a L shaped frame with attachments for the 3 pt hitch.You can add some 2 x 6s for a platform or build a box depending on your needs.
Pete
02-11-2001 17:21:29
Frank, A company called Leinbach makes the nicest one I have seen, it comes pretty skeletal, but has holes to bolt a wood floor to, and stake pockets too! My father (Dave2N on here) has an article with pictures coming out in the next 9N,2N,8N,NAA newsletter. Contact him for more technical info if you want some([email protected]).
Lot's of dealers handle Leinbach attachments. Pete
Al Amstutz
02-11-2001 15:20:07
Hi Frank. If you go to my web site www.al-amstutz.com and click on "My New Toy" link
You will go to a page with pictures of my 8N
with a "platform" I built to haul "sutff" it might
give you some ideas about the 3point hitch device
you were asking about.
I just use stuff I had lying around and it works just great.
AL
Murray Elliott
02-11-2001 16:22:42
 Re: Re: 8N rear box/platform in reply to Al Amstutz, 02-11-2001 15:20:07
Hello Al , I was viewing the board and came across your information regarding your message to someone with "My New Toy" for the 3ph on your tractor, I could not locate. Thanks Murray
