2 btm plow/colters
steve19438
02-11-2001 05:20:25
i may have an opportunity to purchase a two bottom soon. the plow does not have the colters with it. my question is can a good job of plowing be done without the colters??? only my small truck patch will be plowed.
thanks
ZANE
02-11-2001 13:43:59
 Re: 2 btm plow/colters in reply to steve19438, 02-11-2001 05:20:25
The coulters not needed for most plowing circumstances. Fact I can't think of a thing they are good for here in Alabama. I have tried them with every condition you can imagine and always found them more trouble than they were worth.
If you have a heavy thatch on the land they will clog the plow ever few feet. If you don't have a heavy thatch and the ground is hard to begin with the coulters will not let the plow go into the ground.
2fordsmike...No coulters? Mules?
02-12-2001 14:03:34
 Re: Re: 2 btm plow/colters in reply to ZANE, 02-11-2001 13:43:59
Zane: I never plowed a single acre without coulters on the plows, mounted and pull type. We liked the big 18-inch notched coulters Ford offered in the late 50s and felt like they could plow through a bale of hay (which they couldn't, of course). I suppose coulters on an Alabama plow might injure a long-legged mule! Mike-Iowa
bg
02-12-2001 15:13:45
 Re: Re: Re: 2 btm plow/colters in reply to 2fordsmike...No coulters? Mules?, 02-12-2001 14:03:34
I think it might have to do with differences in soil. I very seldom see coulters in use here in eastern NC where we have mostly sandy loam/ yellow clay mix and leaf loam soils.
Fast Ed Ohoi
02-11-2001 09:46:57
Some people take the colters off because they tend to plug things up at times.You should be able to plow ok without.
Al in PA
02-11-2001 08:45:18
I've been using an old Oliver 2X14 for years without colters. It works well as long as the shares are in good shape. My soil has a fair amount of clay (channery silt loam according to the soils map).
