Back Blade
Jim
02-10-2001 06:53:37
What we need is to get zane or some one to invent a devise to put presher down on the back blade on the 2-9-8n. I have a 2n. Still putting it back together.
PS Zane I will be ordering a thing in about 1 and 1/2 weaks.
Jim in AZ.
Greg NE
02-10-2001 19:04:39
 Re: Back Blade in reply to Jim, 02-10-2001 06:53:37
I have a 6 FT Dearborn back blade that has 4 old Ford frontend weights on it and except in real hard ground it digs in real good, needs a new edge for it. Going to do that as soon as my dad can find the new one he bought on an auction years ago and lost in one of his sheds. I'd put a little weight on it and try it, only trouble I have is when pushing snow before the ground freezes and it digs in a little. Good luck Greg NE
Sal
02-10-2001 17:45:33
Hello again, this a interesting post to me. I have had great results with my 8N and a 7' blade in the snow this year, and it did very well with things like sand, gravel, and backfilling a foundation.
For the snow I angle the blade (while driving forward) and it does fine, only had snow build up bad on the tires a few times...not bad for Central NY this year. By my barn I push it back and it does pretty good, sometimes it 'bites in' a bit...but I think I got that in order with a top link adjustment.
It does ok at scraping dirt and turf, but it takes a long time to get very far even with the weight I add.
As for the front blade I have seen the old add on to the 8N where it runs off cables and pullys connected to the 3-point hitch. I hear these are rare and none are being made today...Right?
What do you think an 8N would be like with such a blade? Probably ok for snow and loose stuff, but I don't think it would be really effective at anything heavy or grading...any thoughts...or knowledge of such front blades?
BK8nSoCal
02-10-2001 13:05:17
welded in a piece of cat 657 cutting edge to my 8-n back blade,dug in so good kept stalling the 8n. ended up removing it.now I tilt the edge into the cut and it works better.:]
Al English
02-10-2001 07:34:23
My neighbor found the biggest, heaviest, tallest, thickest, and best cutting edge that could be fitted to his blade. Then he shortened it, put in mounting holes, & bolted it on. Not only did this add a lot of weight to the blade, it is a lot stronger now...Al English
MrJasonl in WA
02-10-2001 07:18:26
I have found the 500lb concrete block I have hanging on mine to be quite effective (and helps with traction as well).
