2N carb
matt
02-09-2001 09:00:26
carb has had a kit put in it but not sure of the depth at which the jets are to be installed at. Do they go all the way to the bottom of the threads?? tractor will run but there isn't any air adjustment at all, turn it in or turn it all the way out--matters not. help N
Dell (WA)
02-09-2001 11:40:40
 Re: 2N carb in reply to matt, 02-09-2001 09:00:26
Matt..... ..well ya' donna hava ta honker down on 'em. (grin)
But on all the jets that I've installed in M-S, Holly, Strongberg, Solex, Webbers, snug has been my practice and have not had any problems.
Most likely, the reason you can't adjust the idle mixture is you're leaking air around the throttle shaft. There should have been a felt gasket to put around the throttle shaft. Hope this helps.....Dell
