Order Ford 8N Parts Online
8N Carburetor ID
John Harrington
02-08-2001 17:44:48
How do you tell which carb you have? I have a repair kit for the TSX-33 / 9N9510A and it is "close". The instuctions show a different carb. My carb has a drain plug and a plug for the chamber under the main needle valve. Also, isn't there supposed to be a seat for the main needle valve? Thanks... just a bit confused
Steve(CO)
02-08-2001 21:25:30
 Re: 8N Carburetor ID in reply to John Harrington, 02-08-2001 17:44:48
My carb has a brass disc on the side on which the carb model number is stamped. Like you, I found the instructions for the rebuild to not exactly depict my particular carb.
