12 volt conversion problem
mac
02-06-2001 18:17:46
I converted the 6 volt sysgtem of a '47 2N to 12 volts. The tractor has a 6 volt front mounted distributor coil. When I start the engine the ballast resistor heats up and within a minute the engine shuts down. If I continue to try to start it the resistor becomes too hot to touch. The engine will only restart after the resistor cools down.
I replaced the old generator with a single wire terminal alternator - a rebuilt Remy Delco. I tested this for amperage with an old multimeter and received no reading.I'm not absolutely sure the meter was accurate though.
Does this problem sound familiar to anyone?
RON/PA.
02-07-2001 03:18:55
 Re: 12 volt conversion problem in reply to mac, 02-06-2001 18:17:46
I HAVE CONVERTED SEVERAL OF THESE TO 12 VOLT AND HAVE FOUND THAT I HAVE THE BEST LUCK WITH GOING TO A 12 VOLT COIL AND ELIMINATING THE RESISTORS.
LOL RON
Bill (in Colo)
02-06-2001 22:36:04
I fried one 9N coil through agressive
jumping from a 12v system.
Most Tractor vendors sell the correct
step-down coil resistor (12v to 6v)
for about $4.
Alternatively, 12v coils for the 9Ns
are available too (around $35).
yep.....Dell (WA)
02-06-2001 20:10:46
Mac..... ...ya' kant run a 6 volt coil on 12 volts. Ya'll overheat it and runt it.
You really need a 12 volt to 6 volt dropping resistor (RU-100 is popular) in series (like flashlight batterys) with your ballast resistor.
Lets hope you're lucky and your 6 volt frontmount ignition coil didn't melt the insulative tar and short out the turns and muck up your sparkies.
If you still have problems after you install the 12 to 6 volt dropping resistor, ask the N-Board. We want to help..... .Dell
Bama8N
02-07-2001 04:34:59
 Re: Re: 12 volt conversion problem in reply to yep.....Dell (WA), 02-06-2001 20:10:46
Dell,
I took your good advise from a while back and bought a new 12 volt coil that doesn't need any resistors. The Advance Auto man knew exactly what I was talking about. Twenty bucks and another potential problem eliminated.
Joel (SoCal 44's)
02-06-2001 19:26:05
You need 2 resistors in series with a 12 v battery, lest ye cook thine coil for supper.
Joel
