4 bar grill guard???
tony moses
02-05-2001 19:51:44
I recently puchased a 4 bar grill guard for my 9n. It is in need of a little straightening. What i need to know is should the bottom bar, below the real heavy one with the hitch coming off, should it be straight across or are the all curved like the heaviest (third ) one
Thanks
2fordsmike...short flat spot in front is correct
02-06-2001 08:35:07
 Re: 4 bar grill guard??? in reply to tony moses, 02-05-2001 19:51:44
Tony: I just had three bumpers restored. And an additional one was in the blacksmith shop with mine. These four helped establish correctness because each had a different problem and several had common correctness. The bottom bar matches the bend profile of the main bar. Note: There is a small flat place on that main bar. Do you see it? You should match that bend profile; a short flat place in front, then curved. The length of the bottom bar matches the bar just above the main bar. The top bar is a little shorter than the other two. All bars have the bend profile with a small flat place in the center. My three bumpers look like the new ones and the undamaged ones I have seen in my 60 years. Although I will say that this flat spot is less pronounced on some bumpers I have seen than on others. Interesting to note that many from-the-factory bumpers have little flaws such as rivets smashed off-center and the hitch point welded slightly one way or the other. We used perfect rivets, but left the hitches just as they came from the factory, totally original. Mike-Iowa
JeffCT
02-05-2001 21:50:51
Tony, If this could help you, the attached link is photos of the front bumper with measurements.
Jeff
RICKWI
02-05-2001 20:00:02
All are curved.
tony moses
02-05-2001 20:06:05
 Re: Re: 4 bar grill guard??? in reply to RICKWI, 02-05-2001 20:00:02
thanks
