Leather back-up ring question
Fessman
02-04-2001 11:51:25
I've decided to change the old 8N style (hydraulic) ram piston over to the NAA oring style. I know I need to soak the leather back-up ring in order to streach it over the piston, but should it be in water or oil????
dave#1
02-04-2001 14:28:39
 Re: leather back-up ring question in reply to Fessman, 02-04-2001 11:51:25
third party image
Funny, when I bought my NAA piston,O-ring and back up washer from my local NH dealer, my back up washer was'nt leather but hard rubber!, seems to work allright????
later,dave
SandyB#TN
02-04-2001 13:33:58
Water is the way to go. Let it soak for about 15 minutes and then take it between thumbs and forefingers of right and left hand and lightly stretch it. Work all the way around the circle. Should pop right on then. Try to put it on dry and it'll break everytime.
Sandy
Old George
02-04-2001 13:27:38
Water works fine, and is not as slippery as oil. I suppose you could soak it in oil also, just makes it easier to go on without tearing when dry. Hope this helps.
Alan Esch
45 2N kit 183513
TimK
02-04-2001 19:05:06
 Re: Re: leather back-up ring question in reply to Old George, 02-04-2001 13:27:38
I soaked mine for about an hour in hot water, then kneeded it for about 10 minutes. I also oiled up the piston so the leather would slide easier.
