Liquid in tires
Barry N Indiana
02-03-2001 06:29:26
I read with interest all of the recent post concerning Anti-freeze and liquid in rear tires. Sounds like a mixture of Anti-freeze and water would work...but being a novice how is it put in the tire? Is it something a tire shop has to do?
Barry N Indiana
02-04-2001 17:46:40
 Re: Liquid in tires in reply to Barry N Indiana, 02-03-2001 06:29:26
Ye ask and Ye shall receive! I have never failed to learn something off this board. Tnx for the info guys. It looks like a trip to Wally World and soon we'll have the 2N tires filled up!
Barry
Pete
02-03-2001 16:42:14
Barry, We use winter formula windshield washer fluid in all our tires. Add a 4oz bottle of waterbed conditioner to each tire to combat algea.
It's cheap, best price we've found is by the case from Walmart,(.68 per gal in summer, .76 in winter, even cheaper than bulk. Non corrosive, doesn't upset encon or kill wildlife if spilled (which means it can be jettisoned right on the ground quickly if the scales are wrong at a pull).
Since it's non corrosive, we us a 55gal drum, a submersible pump ($35.00 at the same Walmart), a garden hose, and a special fitting which all NAPA stores stock, to connect hose to watervalve valve stem. About 25gal. per tire for 12.4-38 tires, about 6.5lbs per gallon as opposed to about 8lbs per gallon of calcium/water mix! Simply fill your barrel, jack one side of the tractor, put valve stem up, put tractor in gear, attach hose to pump and tire, drop pump in barrel, plug it in and pump. Be sure to open the relief valve on the fitting occasionally to let air out. Check every now and then to see how close to the up stem you are by moving wheel forward a little, when you reach the stem level, stop filling, put in your core, and add air to get desired tire pressure. Remember to blow out your pressure guage and pump with compressed air, and your done. Dealers here in upstate NY are paying about .99 gallon for used antifreeze, marking it up about 300% and then charging labor, it adds up quick! Pete
Pete
02-04-2001 07:43:02
 Re: Re: Liquid in tires in reply to Pete, 02-03-2001 16:42:14
OOPS, I meant 12.4-28's, our 12.4-38's take a little more!!!
Arthur Brestlin
02-04-2001 07:16:52
Pete: Thanks for a very informative post! I for one think it's a great idea and will be doing it in the spring as soon as I decide how to safely get rid of the calcium! Do you have any idea as to how cold the solution can withstand? I am also in NY where we sometimes see -10. Thanks again,Arthur
Ed
02-28-2002 19:52:32
 Re: Re: Re: Liquid in tires in reply to Arthur Brestlin, 02-04-2001 07:16:52
I've heard of a sugar solution, that they mix for filling tires, but so far I have not found where or how to get this solution. Has anyone else heard of this ???
Pete
02-04-2001 07:47:53
Art, The bottles claim it is good for -25degrees, and we've never had a freezing problem )knock on wood), one of my buddies claims that by addind 1gal of RV waterline antifreeze to 20 -25 gallons of windshield washer fluid, you can drop it to about -30deg. We are in Upstate NY an so far so good...also checked with encon Police, calcuim chloride/water solution is not damaging to environment, we just put the valve down and let her go, then rinsed driveway. Good luck, Pete
Redbelly1
02-03-2001 10:41:06
you can do it yourself, but i'd recommend you have a friend to help you. those tires get awfully heavy with water in them. I took mine to the tire shop ( had the tires off anyway while fixin brakes). Cost me $10 each tire + the anti-freeze.
raytasch
02-03-2001 07:43:47
There is an adaptor that fits on the large tube part of the valve stem on tractor tires. This adaptor fits between a standard garden hose connection and the tube. You can deflate the tire, pour antifreeze into the tire through the hose and adaptor and then add water to the tire. Top off and adjust pressure with air. ray
raytasch
02-03-2001 11:29:39
 Re: Re: Liquid in tires in reply to raytasch, 02-03-2001 07:43:47
The above proceedure can be performed while the wheel assembly is on the tractor. ray
