Order Ford 9N Parts Online
Jumping a 9n
john
02-02-2001 08:43:56
hello need to know the right way to jump a 9n 6 volt battery thanks in advance the dummy
Claus
02-02-2001 09:08:58
 Re: jumping a 9n in reply to john, 02-02-2001 08:43:56
The correct way to jump a 6 volt battery is with a 6 volt battery. First you would connect negative terminal of the donor battery to the negative of the tractor battery. Then connect the positive lead of the donor battery to a good ground on the tractor away from the battery. This will prevent sparks at or near the battery. An alternate way would be to hook a 6 or 12 volt battery directly to the starter only long enough to start the tractor. The tractor battery would have to have enough energy left in it to run the ignition. In this case, polarity would not matter. Of course for safety purposes ensure that the transmission is in neutral. Obviously, the ignition key would have to be on.
Happy Motoring
Claus
