Order Ford 8N Parts Online
8N Hydralic pump removal
Galen
01-29-2004 17:11:19
How hard is it to remove the pump in my 49? I can't get the arms to move down - tried the diesel thing - figured that since it is winter and I've got nothing better to do - might as well pull the pump and make sure things are as they should be. My F-04 manual is 100 miles away (we're in the process of moving), so can't use it. I'm not planning to tear into it with out the manual - I'm just trying to find out what I'm in for. Thanks
ZANE
01-29-2004 19:43:24
 Re: 8N Hydralic pump removal in reply to Galen, 01-29-2004 17:11:19
Don't remove the pump just because the lift won't go down!
Your oil in the drive train probably has some moisture in it and the control valve is stuck.
Warm the tractor and thaw the oil out and it should work. If it does't then remove the right side inspection plate and wiggle the control rod to free up the control valve.
Drain all three places and refil it with 134 oil.
Be sure it is good and warm when you drain it.
Galen
01-29-2004 20:54:55
 Re: Re: 8N Hydralic pump removal in reply to ZANE, 01-29-2004 19:43:24
Ok Zane - you're the master hydro man! I'll see if I can get it to work that way first.
thanks
North of Fargo
01-29-2004 17:26:33
Sorry about that, the 8N doesn't have the fork to worry about.
North of Fargo
01-29-2004 17:22:57
Not too big a deal. Drain fluid, remove pto shaft, remove side covers, disconnect fork from control valve, drop the pump.
Dachshund
01-29-2004 18:09:44
 Re: Re: 8N Hydralic pump removal in reply to North of Fargo, 01-29-2004 17:22:57
ok - thanks Fargo! by the way - shut that north gate - it's COLD down here!
