Cam follower pin number
Murray
01-25-2004 11:58:03
Need help, locating the parts number for the cam follower pin. Thanks, Murray
BlackDirtKid(TX)
01-25-2004 12:50:41
 Re: Cam follower pin number in reply to Murray, 01-25-2004 11:58:03
Murray, That pin is a 5/16X7/8" dowel pin. Part #73298-S18. Check out your local hardware store or as i did, I used a5/16 rollerchain link pin. Any hardened 5/16 pin should work. Grind it down to right length. HTH.
BDKid Richard
Geo in SD
01-25-2004 16:07:24
 Re: Re: Cam follower pin number in reply to BlackDirtKid(TX), 01-25-2004 12:50:41
An industrial supply house should have the dowell pin you need also.
