Order Ford 9N Parts Online
9N300bI8 ? What Year ?
Bert Brown
01-29-2001 13:34:43
My tractor is weird.
I swear it says 9N300bI8 (with stars) right on the block. All the references I find show 9Ns only have 5 digit serial numbers. What year is it ? Could it be a 2N ?
Other clues are: Its a 3-speed, front distributor, electric igniton, hinged gas/battery cover. To further confuse matters the axle is stamped 2N4015A2 and dated 15-7-47.
Bri9n
01-29-2001 18:47:05
 Re: 9N300bI8 ? What Year ? in reply to Bert Brown, 01-29-2001 13:34:43
Jim your right....a couple of books I have say the last was 296131....Brian.
Jim.UT
01-29-2001 20:27:57
 Re: Re: 9N300bI8 ? What Year ? in reply to Bri9n, 01-29-2001 18:47:05
Well me and Bert proved the books wrong by at least 4000 units!
BTW, the sn 299xxx that I saw was the same one I posted about a few weeks ago. It was parked next to a mobile home that had a "for sale" sign on it. Some asked me if I was going to buy it. I contacted the seller of the mobile home to inquire if the tractor was available, too and was told it was the ONLY thing NOT for sale. Seems they have purchased some acreage about 60 miles away and intend to use the thing. Oh well.... you never know until you ask!
Jim.UT
01-29-2001 16:29:04
Not only is it a '47 2N, it's one of the VERY LAST 2Ns. Somewhere there is a serial number source that claims that the 2N serial numbers ended around 296xxx, since then i found a 2N in my home town with the number 9N299xxx. Yours is even later than that. Last of it's kind!
Eddie S.
01-29-2001 16:03:45
In stamping the serial numbers, Ford used "I" for the number one. What you describe as a "b" is more than likely a "6". The casting date you provided is also a tell-tale sign of a 2N. 9Ns did not have these casting dates. Hope this helps!
Ken N Tx
01-29-2001 14:05:59
The stars indicate that you have .040" steel cylinder sleeves.
Tyler (MD)
01-29-2001 14:00:01
Keep in mind that all 9N and 2N model tractors had serial numbers with a prefix of "9N".
It's probably a 2N. Other things to look for in a 2N is:
third party image
Tyman
Mike NAA 36663
01-29-2001 13:54:55
Try the following link to help identify your tractor. In addition to serial numbers, description of model year changes (improvements?) are included.
Jimp CO
01-29-2001 13:46:45
You are the PROUD owner of a 1947 2N!!!!
Congradulations
