RE: screw type wood splitter
Chris Brown
01-08-2004 17:06:18
someone here about a week ago was wanting info on a screw type wood splitter,here tis.
tlak
01-09-2004 07:45:52
 Re: RE: screw type wood splitter in reply to Chris Brown, 01-08-2004 17:06:18
Last time I sorted this out they did not make one for a tractor, needed a reverse spin.
Lone Wolf
01-09-2004 05:57:21
I have used a screw style splitter however did not find is as useful as a gas powered - hydraulic, 35 ton, maul splitter. I can use it in the vertical or horizontal position-tow it into the woods and use it then leave the mess ( which is minimal)there. Although I never had an accident the screw splitter has more potential to be dangerous if you are not extremely careful. It is fine and dandy to say always be careful but after the fact it is little consulation.
I guess it boils down to what you want but my vote is for the wedge maul splitter.
LW
Ohiosteve
01-09-2004 03:39:21
I have been splitting wood by hand for many years
until last year. I really wanted a 3pt. splitter
but found a good deal on a towable gasoline one.
I have found that this is a better set up as it does not tie up the tractor. I take the tractor
trailer and splitter to the woods and bring the split wood back. I simply put a ball hitch on the back of the trailer and have a little wood
cutting train. Leaves the mess in the woods.
duey
01-08-2004 21:01:16
Safety is in the operator, not in a machine. An axe or splitting maul can be dangerous if the nut on the handle isn't thinking. Hiring some guy to split and stack your wood while you smoke Marlboros in your lawn chair is dangerous to the health, too. Using a claw hammer can be dangerous to the fingers...
I've split a lot of wood with an auger on the 3 point, never lost a glove, a pair of pants, or an arm. Pay attention and stay in the game WHATEVER you're doing. Control the activity so the outcome is what you want.
duey
Phred MN
01-09-2004 09:41:59
 Re: Re: RE: screw type wood splitter in reply to duey, 01-08-2004 21:01:16
Right on!
cak-wi
01-23-2004 10:54:42
 Re: Re: Re: RE: screw type wood splitter in reply to Phred MN, 01-09-2004 09:41:59
phred:
sounds like you may have something and you may be my neighbor. I am looking for info on the bark buster that was made in minnesota I think. I would like to hear from you if you so desire. I have made a ford 3 point cone type that I use (with a safety shutoff) and it works great. I would never go to a hydraulic. anyone that has a ford (9n etc.) and burns wood is missing the boat.
dw
01-08-2004 20:52:32
Stickler also makes a three point mounted log splitter that is pto driven. We used to have one, that we used on our 8N Ford. It worked really well and was fast. Like any other piece of machinery you need careful and treat it with respect. Had no problems with it. We no longer burn wood and did not need it, so we sold it. Was very pleased with it.
Lugnut
01-08-2004 18:51:29
Chris, VERY DANGEROUS. I WOULDN'T HAVE ONE IF IT WAS FREE. Lug
George Willer
01-09-2004 09:13:58
 Re: Re: RE: screw type wood splitter in reply to Lugnut, 01-08-2004 18:51:29
third party image
Interesting you know so much about them. Have you had a bad experience, or are you just guessing? In any event, you can't buy mine. It's the greatest thing since pockets on shirts.
My next step will be to add another level to the carry-all to carry the split wood.
George Willer
Johnski
01-09-2004 12:54:37
 Re: Re: Re: RE: screw type wood splitter in reply to George Willer, 01-09-2004 09:13:58
We sold few of these at a power equip. shop back in the 70's and as I recall they were meant to go on the hub of a pickup or car. I like your setup especially the reaction bar to hold the log. I had a customer who got beat up pretty badly in the legs when the rig he was using on his ford pickup caught a knot and jumped off of the jack. The truck kept hopping across the field on the log and he fell trying to get into the cab to shut it off. To be fair though the instructions call for a kill switch on the vehicle ignition wire. It is supposed to be a pullout type switch attached to a long cord or rope that you stake the other end safely away from the vehicle but in reach of the operator for just this type of situation. Have you given any thought to such a setup for your rig?
P.S. I'm a newbie (first post) but I've been reading y'all for a couple of weeks. Great Site!!!
Chuck A
01-08-2004 19:01:27
Man I am with you. That thing just looks like a killer!.Wow -NO WAY.
Rob N VA
01-08-2004 18:24:01
Interesting. How would you bolt that up to an 'N' tractor? For that matter, it looks like you would need an adapter to bolt it onto the hub of your car. How much does it cost? Please tell me more! I hate splitting wood by hand!---Rob N VA (burning a fire right now, 'cause it is C-O-L-D here in Va right now.
Chris Brown
01-08-2004 18:56:34
 Re: Re: RE: screw type wood splitter in reply to Rob N VA, 01-08-2004 18:24:01
I think they are about $250. If I had one I'd build a 3 point deal sort of like the mount for a hay spike. And mount a couple bearings for the
screw thing to turn on.and use a short pto shaft. There was a post on hyd pto driven wood splitters a while back and someone mentioned the screw thing and said they would like to know more about it.
Rob N VA
01-08-2004 19:37:33
 Re: Re: Re: RE: screw type wood splitter in reply to Chris Brown, 01-08-2004 18:56:34
I would like to know more about hydraulic PTO driven log splitters, if you could point me in the right direction, thank you for your time and response to my question!
