300-6 wooes
joel pohl
01-28-2001 01:45:08
I have rebuilt my 300-6 ford truck motor and have a slight problem! After putting it all together, I lack oil pressure(10 Lbs.). I have been assured by a rebuild shop that all oil galley plugs are in place and have had my crank turned with oversize bearings. A high output oil pump does not help. Pump seems to work fine, but the oil in the oil pan is full of air bubbles after running truck a short time. I rebuilt the whole motor and tried not to take any shortcuts, everything is new, so whats wrong? Any help or web links would be appreciated.
albe
01-28-2001 04:11:57
 Re: 300-6 wooes in reply to joel pohl, 01-28-2001 01:45:08
Joel, You also may want to check the relief valve and spring in the oil pump body. Valve may be hung up or spring is no good or missing. albe
morris
01-28-2001 02:37:06
joel, you have a leak either between the pump and pick up tube, or where the pump bolts to the block. there are gaskets that go between the places that I mentioned. check to see if you cleaned off all the old gasket. hope this helps.
