Order Ford 8N Parts Online
8N starter won't start
John NC
01-22-2001 08:30:50
I have an 8N 1948 and having starter problems. I can take it off, clean and test it;put it back on, and it works for about 10 seconds. I have tried to cross over the solenoid, however, to no avail. I would like to place a new "rebuilt" starter, but find the prices really high $100-$200.Questions:
1> Is there any other test I can try?
2> Is there a starter that can be used that is from a later Ford (or any other make) as they are significantly cheaper.
Thanks for your help!
Steve W
01-22-2001 14:07:04
 Re: 8N starter won't start in reply to John NC, 01-22-2001 08:30:50
I got mine rbuilt for $50 bucks.....they even painted it. Ask around. If you are in upstate NY let me know.
Steve
Claus
01-22-2001 08:47:33
Have you considered doing some repair work on it. Most likely, your brushes need to be replaced. You can get a rebuild kit for about $10.00. As brushes wear and get shorter, the springs have to take up the additional space, and consequently have less tension. Considerable tension is required due to the heavy current that they must conduct to the commutator. If the commutator needs a little bit of cleaning with some 150 grit sandpaper, wrap it around the commutator and rotate your hand. Replace the bearings and it should be almost good as new...
Happy Motoring
Claus
