Order Ford 8N Parts Online
Attaching a trailer to an 8N
burnzee
01-22-2001 06:57:12
How do most of you attach a trailer to your 8N�s? I have noticed pictures of a �V� shaped bracket that is bolted to both the lower links and the drawbar that the ball is then attached to. Its height is adjusted using the top links. Anyone know where you can buy these brackets? Is there another / better way?
Thanks
Greg NE
01-22-2001 17:12:48
 Re: Attaching a trailer to an 8N in reply to burnzee, 01-22-2001 06:57:12
My Dad and I have a 51 8n with the original V type drawbar. It works well but you have to watch out how much weight you put on it, unless you like to live dangerously (Evel Knevel) I have seen almost no swinging drawbars around our area. The best place I have seen to pick up one is to watch your auction bills in your area where the have some old Dearborn equipment or 8N's. I have seen some come out of the back of an old shed where they were forgotten about when the tractor was sold or not needed any more. Greg NE
norm-wy
01-22-2001 15:17:43
Burnzee
I personally use an LW(local welder) brand swinging draw bar hitch which is attached to the bottom of the diff on my 8N. Works for me. FWIW
jim 636-629-6774
01-22-2001 16:47:14
 Re: Re: Attaching a trailer to an 8N in reply to norm-wy, 01-22-2001 15:17:43
i have for sale a 3 point hitch that takes your 2 inch square receiver insert from your truck hitch automatically lifts and lowers your trailer works very well.
Pitch
01-22-2001 10:08:56
I have a drawbar with mine that I have a ball installed on. If you look at the diagram in the other post you will see an item ladeled "swinging drawbar" I put mine in the inner of the two positions and drop a couple of pins in on either side to keep it centered. These drawbars must be a rare item because I have seen more than a few questions about them on this forum. It's funny because I personally have never seen a tractor without one. In all my years around farm and machinery I have never seen anyone pull a wagon or such with the 3 pt. set up. Am I wrong or is it just me?
Paul (WI)
01-22-2001 14:02:59
 Re: Re: Attaching a trailer to an 8N in reply to Pitch, 01-22-2001 10:08:56
During the 20 years that I was growing up on a farm (the 1940's to the 1960's) All we ever used was a 3pt drawbar for all our towing. This was on both a 9N and a TO 20 Ferguson. After I left home, the Ferguson was finally upgraded to a swinging drawbar. I still have both the Ferguson and the 3 piece drawbar. Most of our neighbors that had Fords also used the original 3pt drawbar. You had to remember to take the pto out of gear when using it.
chuck
01-22-2001 11:45:01
My 52 had a swinging drawbar with two pins (bolts in my case) to keep it centered on it when I got it. I use it all the time-the trailer only comes off if I have to put another implement on. I keep the drawbar locked in the inner position, then I only have to take it off for the bushhog or the hole drill. All the blades, rakes, lift arms, shovels, etc. can be put on without taking the drawbar off. I thought it was a common thing too!
chuck
436244
Rick
01-22-2001 08:37:20
I just have a cross drawbar with a ball on it and two short chains. The chains have a d-ring on one end. I use the chains to tie down the lift arms to the rear axle. I pull a round bale hay buggie which causes the trailer tongue to raise up. Without the tie down the hitch will raise up. Something to think about.
ED
01-22-2001 07:12:06
I use two adjustable bars which extend from the top link to the ends of the two lower three point hitch arms. They control the height and the sway of the drawbar. Dont forget to get a "lock" bar to keep your drawbar from spinning over.
Got mine at farm and fleet.
And while you are there, get some more pins for the 3pt hitch attachments - you will allways need one when you don't have a spare!
