Order Ford 8N Parts Online
8N Sleeve size?
David Hilley
01-19-2001 04:45:06
I have 48 8N ser# 53295 Engine sleeve is 3.370"
bore is 3.280", Piston is 3.270" with 4 rings.
I ordered .040 sleeve set, and sleeves were too
small. They fit inside my old sleeves. What do I have, and what do I need? Thanks Dave
dave
01-19-2001 11:24:40
 Re: 8N Sleeve size? in reply to David Hilley, 01-19-2001 04:45:06
I have found out that the block must have been bored to accomidate the .090 sleeves and that it must have had a power kit that used to be available installed. the pistons were definitly not 3 5/16 , but had no oversized marking. I got a set of .090 sleeves and the were OK.
ray md
01-19-2001 09:51:06
Hi David, I have the same problem and was wondering what your pistons are marked ? .030 ?
Claus
01-19-2001 06:00:36
What you have is a mess. Someone bored that block for larger sleeves that were intended for other use, probably in the mistaken belief, that this would increase the HP considerably. Even, if one would like to use the .090 CI sleeves, the block bore would have to be 3.098 (3.097 and .001 interference fit) to give you the 3.187 bore intended for the "N". You will have to do some research and try to find what those dimentions fit and order those parts.
Rotsa Ruck
Happy Motoring
Claus
Claus
01-19-2001 06:42:07
 Re: Re: 8N Sleeve size? in reply to Claus, 01-19-2001 06:00:36
Those dimentions come out to be 154.66 CI... I looked into a Tractor Book and could not find such an animal..
Happy Motoring
Claus
dave
01-19-2001 06:53:12
 Re: Re: Re: 8N Sleeve size? in reply to Claus, 01-19-2001 06:42:07
The .090 cast sleeves are 3.367" OD., and my block
miked out at3.370. Wouldn't they work?
Claus
01-19-2001 07:21:47
 Re: Re: Re: Re: 8N Sleeve size? in reply to dave, 01-19-2001 06:53:12
I screwed up in my calculation. I subtracted .090" from the bore instead of adding .180". (3.366) Yes you are correct and the bore size for the .040 sleeve would be 3.266 allowing for .001 interference fit.
Sorry for the wild goose chase..
Happy Motoring
Claus
