3 point hitch will not lift my box blade.
Brad
07-09-2003 08:33:46
Where's the best place to start? Does anyone have any good pictures to assist me?
Since I've had this 8N, when I stopped the engine, the box blade would come down within a few minutes. Now, it won't go up past about an inch or so off the ground.
Help!
Dave OH
07-09-2003 15:26:49
 Re: 3 point hitch will not lift my box blade. in reply to Brad, 07-09-2003 08:33:46
Quick leak down would indicate the cylinders are leaking or the pressure releif valve is not seating properly. Pull the plate on the right side of your tractor, (the one with the dip stick in it), start the tractor and engage the lift. If you see a lot of fluid comming from the top area the cylinders need rebuilding. A little dripping is normal. Look down at the fluid, which should be just a little lower than the opening you are looking into and if you see a swirling of the fluid the pressure releif valve is not seated and needs replaced. Other than that you may have pump problems but I doubt it. Dave OH
Pitch
07-09-2003 14:32:04
Number one go to the basics. You do have a clean full hydraulic resivior don't you? I know tthat may seem condenscending but you would be suprised at the number of people who don't. If it hasn't been changed since you owned the tractor no is the time to do it.
