Ballast
bob
01-10-2001 16:32:08
do all 12 volt con. require a ballast resistor or can they be ran with out one my 9n is set up with out one my 8n has one wahts up bob
Claus
01-10-2001 17:39:31
 Re: ballast in reply to bob, 01-10-2001 16:32:08
third party image
Most 12 volt coils need a ballast resistor. Some do not.. Just like cars, Only some American Motor Cars did not require a ballast since the coil had one internally. If you measure the primary coil resistance and it is close to 3 ohms, then you do not need a ballast resistor.. Now if you run a 6 volt coil with your 12 volt conversion, you will need an additional 6 volt dropping resistor in series with the ballast. Side mounts also except they do not have a ballast.
Happy Motoring
Claus
