A few months ago I bought a later model ('45-'47?) 2N to maintain a few acres of horse pasture and fields. This is my first "old tractor." Before I got the 2N my neighbor had been letting me use his new 4wd John Deere to bush hog, level, etc., so needless to say it is a bit of an adjustment trying to get used to the older equipment. After a carb rebuild, a rebult 12v generator, new VR, and a complete rewiring job (with help from the N board), I finally have it starting and running pretty well. Last week was the first time I actually got to put it to work, using a 6-ft blade to level a deeply rutted, muddy access drive to the pasture. Even in the deep mud, the tractor performed remarkably well, but I noticed that the hydraulics could not maintain the blade in any position other than fullly raised or fully lowered. When I move the touch control lever forward about 2-3 inches down from the top position, the lift arms begin to lower (which is approximately per the specs indicated in the FO-4 manual) but the implement continues to lower all the way to the ground regardless of the position of the lever below this point. In other words, the hydraulics seem to be sort of an "all or none" operation on this tractor. Being a 2N it doesn't have position control, so there is no way to maintain a consistent height other than the touch control lever. I also notice that when I turn the engine off with the load in the air, the implement immediately lowers to the ground. It doesn't exactly come crashing down, but at the same time the tractor shows no indication whatsoever that it was designed to keep the load up when it's not running. (With the motor running, the load will stay raised in the max position til the cows come home). I read somewhere in the archives that the hydraulic system should keep a load up for a period of time after shutting off the motor. Are these things typical of a 2N hydraulic system, or do they indicate a problem somewhere?Meanwhile, the pasture is getting out of control, and I'm planning to buy a 5-ft bush hog soon to cut it back. Even if the hydraulics aren't acting exactly as they should, I don't really see why I couldn't use it to bush hog, since I plan to use limiter chains to maintain control of the cutting height and don't intend to leave the hog sitting in the air after I'm done with it. Is my thinking out of line here? Sorry about my wordy post, but I would appreciate any help or advice about this from the board. Thanks! bob
