I've never cared for the stock wiring arrangement for just this reason. There is no overcurrent protection at all in the system. Many modern cars are wired so that the main power to the ignition, accessories, etc feeds through a fusible link, usually near the alternator, instead of connecting to the battery post or the starter solenoid. The astute "pick your part" junkyard shopper can obtain an alternator complete with a fusible link and heavy guage charging wire. Clip the harness carefully to obtain the wires you want, but make it look like you just mindlessly hacked away with wire cutters and barely know what you are doing. The nice man at the parts counter will just charge you for the alternator and ignore the bonus wires. Connect the heavy wire from the alternator to the starter solenoid/start switch and thence the battery. Use some 12 guage wire to splice the dangling end of the fusible link at the alternator post to the junction block at the dash. (Instead of connecting the junction block to the start switch). All the wiring in the tractor is then protected from gross overloads by the fusible link, except the main battery cable and charging wire (which are impractical to protect in any event). This does create, in effect, a "4-wire alternator", which might be viewed as too complicated or unattractive to some. You can "clothe the unsightly" with some red spiral-wrap and it almost looks stock.
