It's a 52 model
DallasGa- Ha Da
06-27-2003 13:21:02
That 8N on ebay is a 52 the serial given is from early 47,It can't be it has a side mount dist.The engine casting is from Sept.6 or 8,1952.The casting code wouldn't have 8N with it in 47. If you add a 5 to the front of the serial that's given, that would be about right,"513XXX"just about the end of production in late 52. hth Dallas
darren
06-30-2003 20:30:17
 Re: It's a 52 model in reply to DallasGa- Ha Darren, 06-27-2003 13:21:02
third party image
Link WRONG! THE SHIFTER DOES'NT HAVE PLASTIC KNOB AND NO PROOFMETER ON DASH OR A hole for one. "No proofmeter. There is no knob on the shifter at all - kind of a metal cylinder on top that is bigger in diameter than the shifter" thats from the mouth of the owner.
darren
06-30-2003 20:37:09
 Re: Re: It's a 52 model in reply to darren, 06-30-2003 20:30:17
also the serial number is 13761 which makes it made in 1947 where do you get the side mount distributor from?
