12volt
misty
01-09-2001 19:55:57
Installed a 1 wire 12 volt alternator. It won't show a charge until I disconnect the governer, and allow it to rev way up. Any other way to excite the alternator?
yep.....Dell (WA)
01-09-2001 21:04:44
 Re: 12volt in reply to misty, 01-09-2001 19:55:57
Misty..... ...Thats the problem with 1-wire 12 volt alternators conversions and the low RPM N-Tractor engine.
Most 12 successful 12 volt conversions connect an "excitation" wire from their ignition switch thru an "isolation" device like a dashboard alernator worning lightbulb or a "diode" to the #2 terminal on the alternator.
If you don't isolate, you will not beable to turnoff your engine as the alternator will "feedback" to the same terminal that the ignition coil is connected to and no matter what you do with your ignition switch, the engine will still continue to run.
I could continue to tell you how to successfully convert to 12 volts but there are several web pages that have done it better with diagrams and pictures. You might want to search the web for answers. You might also want to check the "archives" at the top of this most excellent N-Board. Read 'em and weep. More dog-gone problems in converting.
I'm a 12 volt advocate for the right reasons. And I know how to do it right. That said, I still haven't found the right reason to convert my eazy starting 6 volt 8N. Remember the 6 volt mantra, "clean, bright, and tight"..... ....Dell
To Dell
01-10-2001 06:47:05
 Re: Re: 12volt in reply to yep.....Dell (WA), 01-09-2001 21:04:44
Dell:
Does your answer mean that there are either 1 wire or 2 wire alternators, and that 1 wire alternators won't work ? I have also an easy starting 6v, but some day..... ..... .
Thanks
TimK
well.....Dell (WA)
01-10-2001 08:00:10
 Re: Re: Re: 12volt in reply to To Dell, 01-10-2001 06:47:05
Brian is correct.
1 wire 12 volt alternators work fine if you rev your engine up to "get their attention".
3 wire 12 volt alternators work fine on the low revin' N-Engine.
Ya' pays yer monies and takes yer choices..... ....Dell
Brian *N* S. IL
01-10-2001 07:31:25
Yep, there are 2 styles of Delco Remy alternators, the "one wire" and the "3 wire"; the "3 wire" is much preferrable on the N series tractors for the 12 volt conversion.
ray to brian
01-10-2001 12:12:20
 Re: Re: Re: Re: 12volt in reply to Brian *N* S. IL, 01-10-2001 07:31:25
Thanks for all the info. and where did you get
your belly draw bar ? Does it slide ?
Brian *N* S. IL
01-10-2001 23:13:54
 Re: Re: Re: Re: Re: 12volt in reply to ray to brian, 01-10-2001 12:12:20
Ray,
Yep, it will slide in and out, and I think there are about 3 or 4 different lengths you can "set" it at. I keep mine at the shortest length, and that way I don't have to remove it to do anything except when I put on the plow (and then the ORC has to come off too :-(
I got the swinging drawbar from Buchheit's, in Perryville, MO. Buchheit's is a farm store like Tractor Supply Company (I would assume, having never been to a TSC), or Rural King, or....??? You shouldn't have too much trouble finding the swinging drawbar assembly(s) that you need...they're pretty common and the same parts fit several different tractors besides the N's. If I remember correctly, everything needed to install the swinger cost about $100, and it is worth every penny to me. If you can't find a store that carries them or can order the parts for you, just go to your Ford/New Holland dealer, and they can set you up too. Also, I believe that Walt's Tractor Parts and also Just 8N's also can get them for you.
chuck
01-10-2001 07:30:23
I put a one wire 37A altenator (CT Farm kit) on my 52 8N about 6 years ago. It works fine. I do notice that on cold start up it doesn't immediately charge. In less than 30 secs it is charging-I sometimes rev it up a little to get it going but most of the time I just pull away and later notice that it is operating. The benefit I have found is that I was replacing 6 volt batteries every two years. With the altenator I still have the battery I put in it when I changed over 6 years ago. Also, I can turn on both headlights and the spotlight on the rear fender and they stay bright even at minimum idle speed. I usually am putting it away in the dark and this is great compared to the dull yellow light I used to have when it idled down. Other benefits-Genese (sp?) pointless ignition that I have never had to touch since installation, no miss at idle, lower idle speeds, elimination of all resistors in the tractor with a 12v coil, and now I can use the tractor to jump start all of the other thingees with engines that I have around the place. It is sure easier to pull up the 8N than one of the cars that does have a good battery trying to remember which side the battery is on. The 8N is the lowest maintenance, highest reliablity engine on the property with it's up-to-date electrical system. It certianly starts the fastest-I would say it starts on the first or second cylinder firing when cold and the first when hot-I never do more than bump the starter switch (except when I forget to flip the second ignition switch under the cowl for kid/theft protection).
chuck
436244
smart man..........Dell (WA)
01-10-2001 07:54:35
 Re: Re: Re: Re: 12volt in reply to chuck, 01-10-2001 07:30:23
Sounds like you found the right reasons to convert your sidemount 8N to 12 volts and you did it right..... ...Dell
mel
01-10-2001 17:11:50
 Re: Re: Re: Re: Re: 12volt in reply to smart man..........Dell (WA), 01-10-2001 07:54:35
I bought an internal regulator to convert an alternator to one wire. The instruction mentions connecting one more wire to get a lower rpm kick in. do all of them have this option?
yep.....Dell (WA)
01-10-2001 18:36:39
 Re: Re: Re: Re: Re: Re: 12volt in reply to mel, 01-10-2001 17:11:50
Mel..... .as far as I know, what you say is probably true.
But I am NOT an alternator rebuilder expert.
Heres my take 1 wire vs 3 wire Alternators.
1 wire conceptionally seems to make a lot of installation sense BUT because of tractors low RPM operation, does not really charge well. Of course if you operated up at 5000 RPMs like the chevy V8 it was designed for, no problem.
The 3 wire alternator seems to charge at low RPM because excitation is ignition switch provided to #2 terminal. The problem is that same switch connection also goes to the ignition coil. So far, so good. UNFORTUNATELY, when you go to turn the engine off with the ignition switch, it doesn't turn off BECAUSE the #2 alternator connection somehow is backfeeding 12 volts to that same ignition switch terminal that goes to the ignition coil.....an' vola'.....the engine keeps running. Therefore, you need some form of "isolation" in that #2 wire to prevent backfeeding 12 volts to the ignition coil. The simplest way, is to do it like chevy does it, wire an alternator idiot light in the #2 wire. Or you can be more "exotic" and use a diode but using a diode you have a 50/50 chance of installing it incorrectly and then nothing runs.
There has been many messages to the N-Board about this 12 volt conversion process. I suggest you might want to check the "archives" at the top of this most excellent N-Board. I can think of at least 4 Web sites that have excellent 12 volt conversions articals. You might want to check some of the side boards for more information.
And no, I don't have a web page..... .....Dell
mel
01-10-2001 17:11:29
