Order Ford 8N Parts Online
50 8N lift arms
dan shu
06-26-2003 06:43:43
was looking at my 8N last nite and noticed the shaft of my left lift arm is rounded kinda oblong and my right one is kinda squared off and blocky and thicker...does this mean one has been replaced or are they supposed to match....thanks a lot
KCM
06-26-2003 07:33:01
 Re: 50 8N lift arms in reply to dan shu, 06-26-2003 06:43:43
There was a revision to that particular part. 9N's, 2N's, and most 8N's all had the more rounded style of arm. The last 8N's, around 1952, used the square style, and all replacements were the square style. Evidently there was a problem with the rounded style breaking and the arm was revised and beefed up to solve the problem. One of yours must have been replaced sometime in the past.
klf
06-26-2003 19:02:01
 Re: Re: 50 8N lift arms in reply to KCM, 06-26-2003 07:33:01
The replacements I sell are rounded just like the original. I haven't seen the squared off one in years. As far as matching, it is up to you. If you are using it for different jobs around the place and such; don't worry about it. If you want to restore it and show it, thats different. If it works and doesn't bother you, leave it alone. The decision is up to you.
dan shu
06-26-2003 11:13:43
thanks...everything works ok...neve noticed till i read the board for last 2 months...cant believe what you learn from this site
