850 Squeal When Hot
Mark
06-25-2003 10:19:23
After plowing for 15 minutes, my 850 squeals loud. It comes from the left side by the carb or starter, but it's so loud I can't pinpoint it. Once it starts it does it mainly during idle, and if I drive forward with plow raised it will quiet down while going up slight incline (slight load), then sqeal again when the terrain levels off or is down grade. It sounds like a loose belt but it's not coming from the fan belt or generator area. If I let it cool for 30 minutes it goes away. Help?!
souNdguy
06-25-2003 12:58:04
 Re: 850 Squeal When Hot in reply to Mark, 06-25-2003 10:19:23
When i got my NAA it squealed loudly... it was a combination of a loose belt, and also the alternator fan was actually rubbing on the algled bracket... funny enough, when I tightened the alternator belt.. the belt stopped squealing, but the rubbing fan squealed worse...
A few minutes with an angle grinder fixed it..
Check all your belts, and try some belt dressing. Occasionalyy you can hear water pump squeals.. or even bearing squeals in alternators.
Soundguy
