A dwell/tach normally connects one lead to the distributor side of the coil, the other to ground. Sometimes there is a third lead for +12V, sometimes internal batteries, sometimes neither. If the meter needs power, and doesn't have it, it will typically read strangely. While it is possible to create a meter which can measure RPM from the plug wires, most dwell tachs will neither appreciate the high voltage, nor adjust for the "divide by 4" effect of sensing just one cylinder's firing event. In your case, your "300" RPM might have been 1200 RPM/4, and your "600" RPM might have been 2400 RPM/4, and the dwell/tach meter was actually sort-of working. Front mount setups make it difficult to access "the disributor side of the coil." You may be able to get a satisfactory reading by connecting to the battery side of the coil, assuming that your 12 volt conversion uses some sort of resistor in series with the coil. The dwell won't read right, but the periodic voltage rise/fall should be sensed as "the points opening" and provide an RPM reading.
