Order Ford 8N Parts Online
3sp 8n?
bill
06-23-2003 20:06:27
can it be or is this a mishmosh
Dave OH
06-24-2003 20:14:56
 Re: 3sp 8n? in reply to bill, 06-23-2003 20:06:27
My neiphew called me about his son-in-laws (8N) with a three speed? He needs an engine as he blew his. I told him it was a 9N/2N with an 8N engine with front mount distributor. Or someone changed the tranny at one time. If you go the the Smith Tractor site you can look up the casting numbers to see what was changed. "www.8nford.com".
Dave OH
Lee
06-24-2003 13:39:49
Here in Mo. I've seen a number of 8N/9Ns or 9N/8Ns. 8N front ends on 9N 3 spd tranny & differential or 9N front ends on 8N 4 spd tranny and differentials. Seems like lotsa tractors were made outta the parts that still worked from whatever was sittin' in the shed.
Later, Lee
Rusty 2N
06-23-2003 20:17:19
yes!!! I got one sittin in my shop!!! Not really the engins swap perfectly. 4 more HP why not. It's been farmerized!!!
souNdguy
06-24-2003 12:06:22
 Re: Re: 3sp 8n? in reply to Rusty 2N, 06-23-2003 20:17:19
Speaking of farmerizations.. Yesterday I was wondering if the back half an 8n would attatch to the front half( post transmission ) of a 9n. This was just a 'curious' question.. but Dell was kind enough to answer it.
Though a hodgepodge.. how about this animal...
9n tractor... changed out with a 52 8n engine and improved 3 wire charging system/regulator and starter w/ solenoid, remove the rear casting behind the tranny, and add the rear casting of a late model 8n..get the extra seals in the axles, draft/position control, easier hubs/brake system, and area for the drawbar mount .. right?
I wonder if there are any machines out there this gene-spliced..? Somewhere along the lines.. someone had to do this...
I guess the only 9n/2n parts would be the front axle and support, and the tranny/steering/sheetmetal.. etc..
Soundguy
DON TX
06-23-2003 20:14:50
Could be or it could be hard to see the 4th gear marking. Lots of grease, oil or rust could cover the "4" in front of the gearshift. Mine is caked with dirty oil and had to wipe it off to see it just now. HTH DON TX
