24 volt set up
Tom
06-22-2003 02:10:23
I was just wondering the pros and cons of a 24 volt set up on a 9N vs. 6 or 12 volt.
Looking to buy a tractor that has this.
Thanks
Tom
Mike S
06-22-2003 05:06:11
 Re: 24 volt set up in reply to Tom, 06-22-2003 02:10:23
You might check and see if they are not just using two batteries in parallel to just give 12 volts with more amps. I have seen some guys do this to run 12 volt spraying systems from the tractor. My neighbor has two large electric driven spreaders that work that way too.
MikeC
06-22-2003 03:35:09
Tom,
I'm not sure why someone would set up an N with a 24 volt system. That is some serious overkill. However, if it runs good and the price is right, why not?
Salmoneye
06-22-2003 02:24:25
Works great!
I run my DVD, microwave and my hair dryer while brush hoggin...
Rob
06-22-2003 02:29:06
 Re: Re: 24 volt set up in reply to Salmoneye, 06-22-2003 02:24:25
What do you use the hair-dryer on?
That's...
06-22-2003 02:40:38
 Re: Re: Re: 24 volt set up in reply to Rob, 06-22-2003 02:29:06
Rather personal, and I don't want to talk about it...
Salmoneye
