Order Ford 8N Parts Online
8N STEERING LOCKED
HANK
06-20-2003 10:40:36
MOWING WITH MY 8N MAKING A RIGHT TURN. STEERING LOCKED AND WON'T RELEASE.
PLEASE LET ME KNOW THE LONG-TERM AND
THE SHORT-TERM FIX. RIGHT NOW SHE'S SITTIN
IN THE MIDDLE OF MY YARD.
souNdguy
06-20-2003 22:22:13
 Re: 8N STEERING LOCKED in reply to HANK, 06-20-2003 10:40:36
If you have much verticle play, it is possibly as suggested.. dead bearing. And tearing down the steering box isn't much fun anyway.. and even less if it is way out in the field.
Got another tractor with a lift, or a trailer . You can jack the front of the N up.. roll the trailer under it, comealong it or chain it in place, pop it in neutral, then tow it back to your barn to fix it in the shade.
Or you could pop the draglinks off and tow it backwards.. carefully ..but I would opt for the trailer /dolly method myself..
Gotta take the hood / gas tank off, bumper, battery box, and throttle / choke linkages.. attatched wiring and gauges / oil line...
Have fun. It is a bit time consuming.. but can be done... I did mine. The diagrams in the fo-4 manual helped.
What year is yours.. mine is a 5s, and has the late model steering box.
The early one is similar in design, but adjusts differently.
Let us know if you need more info.
You might wiggle things a bit once you get that front end jacked up.
good luck
Soundguy
HANK
06-21-2003 04:08:42
 Re: Re: 8N STEERING LOCKED in reply to souNdguy, 06-20-2003 22:22:13
I HAVE NO VERTICAL PLAY.
COULD THIS BE A DIFFERENT PROBLEM?
Dell (WA)
06-21-2003 11:04:46
 Re: Re: Re: 8N STEERING LOCKED in reply to HANK, 06-21-2003 04:08:42
Hank..... ...there is NO OUTSIDE the steering gearbox FIX.
BYTE THE BULLITT, get out your I&T FO-4 manual and start wrenching. You won't know what the problem is until you EYEBALL it..... ....respectfully, Dell
bg
06-20-2003 12:06:51
The top bearing has probably deteriorated and the pieces have fallen down in the sector gears. That's what happened to mine. Only fix is to tear the box down, replace the bearings.
