Order Ford 9N Parts Online
9n's
Larry
01-09-2001 06:47:51
When I got the first 9n, I didn't know much about anything to do with tractors, except that ever since I saw a neighbor working with his 9n, I've always wanted one. I probably paid a bit too much for it, but it's really great to have. Then I got another one at auction really cheap. Not as pretty, but it ran and it was cheap. I was going to finish restoring the expensive one and use the cheap one for work. After reading this board and learning alot, I realized that the "pretty one" is actually the one I'll use for work. It has been partially converted to 12 volt, still uses 6 volt generator, but a 12 volt battery. Also some parts on it aren't original. And the other one turns out has almost every original part still intact and in decent condition! Who knew? The transmission on the cheap one makes a slightly constant grinding noise if I shift it too fast or while moving. Any thoughts?
Steve W
01-09-2001 06:55:30
 Re: 9n's in reply to Larry, 01-09-2001 06:47:51
N's aren't made to be shifted while moving....you pick a gear for the job, and let the clutch out from a stop....to shift to another gear, you STOP, then shift again. But if your clutch doesn't disengage quickly, and you try to shift before the tranny stops moving, it will grind. I'd start by checking you clutch adjustment. If that doesn't work, there are lot's of possibilities. An easy way to see what is going on is to pop off the tranny filler cap, and look while you press in the clutch. Things should stop pretty fast.
Take Care
steve
Fred OH
01-09-2001 14:39:23
 Re: Re: 9n's in reply to Steve W, 01-09-2001 06:55:30
Steve, we might make another comment about the shifting. After they get warmed up real good when you are mowing and the oil thins down some, they get a little more rakey when shifting gears. It is best instead of grinding the gears to stop, idle down and give the input shaft more time to stop spinning before changing gears. You'll notice it next summer when you think about this post as you are mowing and grind the gears. L8R----Fred OH
Brad
01-09-2001 06:53:53
These tractors don't have synchromesh, they're not designed to shift on the move. Your supposed to start out in the gear you're going to use. You might try double clutching but I doubt you're going to have enough road speed to pull it off. You have to work the throttle, the gearshift and clutch all at the same time as steering...sounds like a wreck waiting to happen.
