Order Ford 9N Parts Online
1939 ford 9N transmission problem
scott
06-14-2003 22:58:29
just purchased a 39 9n.. trans keeps poping out of 1st gear can someone tell me how to fix the problem????? ?i.e manual i can down load off the internet..... ..... .
BOB
06-15-2003 16:49:35
 Re: 1939 ford 9N transmission problem in reply to scott, 06-14-2003 22:58:29
Scott, sounds like need to replace the rod and detent ball or just the spring only to hold in gear. what it involves
1-remove hood
2-all wiring
3-drag links at steering box
4-then remove the hole top trans cover with steering post and all
5-BUT here is the real kicker!! better sit down for this one maybe have a beer, YOU got to split the tractor to get to the shifter rods, sorry no other way 6-if it was me stay out of 1st or just hold shift lever when in 1st till you have to split tractor
7-good luck BOB
Robert (TX)
06-15-2003 03:33:45
If you want an electronic version of Ford N manuals try the link below.
http://www.grogansports.com/satsoft/products/Nset.html
Jack
06-15-2003 00:31:45
Check the archives. That's your "online manual". :-)
From the archives:
Link
Link
Link
Jack
