Levelling a rotary cutter
Whit Trovillion
06-14-2003 09:32:15
I am pulling a Woods M5 with a Massey Compact Utility. I found that in order to level the deck of the bush hog, I have to keep the 3 pt. about 3/4 of the way up at all times. I feel that always having pressure on the left arms like this is sapping horsepower away from my PTO and ground speed. Is there some sort of chain leveller I can get to stop the front of the cutter from dropping all the way into the dirt when I lower the 3 pt?
Rob
06-14-2003 09:45:48
 Re: levelling a rotary cutter in reply to Whit Trovillion, 06-14-2003 09:32:15
The front of the mover hangs on the chains. I hear F/NH sells the limiter chains for $25, dunno. I made mine but I have a lot of chain around here.
'52 8N (MD)
06-14-2003 09:42:07
There are two things here to look at. One is check chains the other is how rotary mowers work. The New Holland rotary mower I have recommends the front of the mower be a little closer to the ground than the tail end. This aids in the rear discharge of the grass and helps keep the RPM's up. Check chains are a must to keep the cut level and your PTO unstressed. BTW, a good place to hook up the check chain adapters is on the rear axle flanges that protrude from the axle housing on either side of the top link assy.
....and a good place for
06-14-2003 11:09:40
 Re: Re: levelling a rotary cutter in reply to '52 8N (MD), 06-14-2003 09:42:07
is the lift arms. I drilled out the rivets for the linch pin holders and installed a couple of tabs made fron 1/4" X 1 1/2" strap. The tab extends about an inch above the arms, with a 3/8" hole in them. I keep linch pins in each implement, so I didn't need them anyway. They work well. This prevents running out of room on the lower pins, since I use the sway bars on nearly every piece of equipment, too.
Ron
Oops!..
06-14-2003 11:11:45
 Re: Re: Re: levelling a rotary cutter in reply to ....and a good place for , 06-14-2003 11:09:40
That should have said, "....and a good place for the lower connection is the lift arms" (musta run out of room).
Ron from IL
