Loaded Tires
KC (Alaska)
06-08-2003 10:40:23
How much fluid does it takes to fill the rear tires ( 11.2x28)
Rob
06-08-2003 12:27:26
 Re: Loaded Tires in reply to KC (Alaska), 06-08-2003 10:40:23
A 10-28 can hold 90% fluid or 23 gals. With valve filling methods and no special equipment you can only fill to 0.8 of that amount. That is based on 5# of calcium chloride per gallon of water which prevents freezing. 310# is the weight of the 23gals. So says Ford.
KC (Alaska)
06-08-2003 22:00:03
 Re: Re: Loaded Tires in reply to Rob, 06-08-2003 12:27:26
Thanks for the info I'll be filling them with 50/50 antifreze.
