Just replaced an old Ammemeter with a new one and.
Bill Marcy
06-06-2003 17:16:38
There is no place to put the wire from the distributer (?), there is just the two bolts on the back that the rear plate slide over. Is there a trick to getting this to work?
JimNC
06-06-2003 17:42:12
 Re: Just replaced an old Ammemeter with a new one in reply to Bill Marcy, 06-06-2003 17:16:38
Most likely the bracket that holds it to the dash panel goes on first. It should have 2 plastic insulators on it. And the wires use the same studs as the bracket. Should have been some destructions in the package. I know, if your like Me you threw them away. LOL. Somewhere down on the case of the ammeter there is a (+) (-) that will tell you which stud is which.
Jim
Rob
06-06-2003 17:41:48
Two things. You have the modern ammeter and you have to connect a wire to each of the studs that mount the ammeter. There is now 'loop.' They are insulated from the dash. That meter should be between the battery and the ignition switch. The coil should be on the other side of the ignition switch.
J52J
06-07-2003 04:45:01
 Re: Re: Just replaced an old Ammemeter with a new in reply to Rob, 06-06-2003 17:41:48
Is there a diagram some where to hook up an Ammeter? I just ordered a new Ammeter for my Jubilee.
thanks
J52J/Jess
Tyler has one! Rob
06-07-2003 13:07:35
 Re: Re: Re: Just replaced an old Ammemeter with a in reply to J52J, 06-07-2003 04:45:01
But he won't post it! What's up with that? The archives don't work or I would have found one for you....
J52J
06-07-2003 13:56:14
 Re: Re: Re: Re: Just replaced an old Ammemeter wit in reply to Tyler has one! Rob, 06-07-2003 13:07:35
Thanks for the Info.. Maybe if you keep poking at Tyler he'll post the pic..
It takes all kinds to make the " N " go round.
J52J/Jess
Tyler (MD)
06-07-2003 21:15:38
 Re: Re: Re: Re: Re: Just replaced an old Ammemeter in reply to J52J, 06-07-2003 13:56:14
I just have a wiring diagram. That may not help you.
Tyman
J52J
06-08-2003 04:06:09
 Re: Re: Re: Re: Re: Re: Just replaced an old Ammem in reply to Tyler (MD), 06-07-2003 21:15:38
That's ok.. Thanks for the Reply.
J52J/Jess
Rob
06-07-2003 05:37:22
I'm sure one of these guys has a diagram but I want to TELL you where the ammeter is because it's good to understand, without a diagram. (I'm in kind of a hurry, rain is forcast.) Anyway, your ignition switch has a wire from the battery, actually probably from a post with a big cable connected to the battery. The other side of the ignition switch goes to the ignition circuit and the charging circuit, the tractor. One side to the tractor and the other side to the battery. You put the ammeter in that wire to the battery. Then the ammeter shows you what is happening to the battery and also what is happening to the starter and the genny. Amps out Amps in. Battery powering the starter and coil = amps out. Genny charging the battery = amps in. Get your mind around that and you understand what it is telling you and you will have no problem understanding where to wire in that meter. Or any other ammeter. HTH
